Re: New sound...Yay!
Originally Posted by Cam
Could be a wheel bearing in the beginning stages of failure...or pretty much anything else back there. Then again, it could be the sway bar. Take a look at the rear sway bar and if the bushings are in good condition just use some lithium grease or other lubricant on them and reinstall.
One thing I can add is that it seems to make this noise regardless of which way I am turning. It is possible both wheel bearings are going at the same time but that is unlikely and especially considering one has already been replaced. The sway bar is an interesting possibility but it is making more of a metallic sound than a clunking sound.
Tony
