Originally Posted by MarquisDePosa56
Ok....so just that I have this straight, cause the Bluetooth is important to me, I'm in sales and spend 60% of my day on the road.
Thing won't recognize when its parked so you will never be completely compatable with the Bluetooth or play video unless you install the special adapter?
Or
Its will only work properly with my Bluetooth and play video when I am parked?
And, where does one buy the devise that makes everything work as it should?
First, it will do blue tooth perfectly, though you need to do "voice dial" or use the handset for dialing if your not "parked" or so they seem to imply. The on screen, the number pad will not work if it thinks your "moving".
I believe the "correct" adapter can be gotten from any stereo place. However I believe the adapter is just a relay. My installer only installed a relay and most of the functionality is there. I have only a couple never used options that tell me I can not use them as im not "parked" Those options are auto eq setup and if I remember correctly a screen calibration tool. Of note though I have never had any trouble with the screen calibration and all manual EQ settings work fine.
