Re: 92 temp guage almost to the red
did the tests and the fans were not running i switched all of the relays and fuses and tried again and still nothing. so i decided to take them all out and put them back in again and make sure all of the connections were tight drove the car home temp gauge went to normal and stayed there wasn't sure if it was due to the weather that it didn't overheat since it is 26 right now so i popped the hood when i was home and saw the fans running so hopefully everything will be fine now thank you for all the help
