Torn driver's seat..
Is it possible to get my fabric (and vinyl?) seats repaired? I just need a new section of vinyl.. on the entry side of the driver's seat .. where I rub on the outer side (upright) of the back section (rub when getting in/out). The passenger side looks fine.
OR.. Can we get stock covers (skins) to replace the entire seat upholstery (over the stock foam?)?
My car is a definite "driver" .. so, I dont need perfect interior.. I would just like to replace that one vinyl (foam popping out in 2 small holes.. about 1" diameter) section.. ?
Thanks, Jim
Jim
