Re: Trouble Starting
Haven't pulled the cams yet. Mike seems to think that may lifters need to be rebuilt. We'll see. Once I pull the lifters, I'll check to see if the valves are holding pressure. If they are, then it is just a matter of determining if the lifters have enough travel with the larger base circle of the cams. Getting the lifters rebuilt will only cost a bit over $120. It is just the time to pull everything apart including the timing belts and remove all of this crap. Seems like this is never ending. If the lifters don't squeeze enough or the valves to seal completely, I'm going to be pissed. Bottom line, I hope this is it. This project has really worn on me.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
