Re: Engine check light flashing
Originally Posted by briansvx
it is a constant flashing even after the engine is fired up and in driving mode too. if it's misfire, would replacing spark pulgs solve it?
I'll also look into the kick panel code reading procedure as well. much appreciated!
my 100% real carbon fiber lay-over plastics + blk suede interior conversion is about done. can't wait to share!
fingers crossed that the long storing for the interior conversion would not cost me major engine problems...
thanks for the advice!
You might first look under the driver kick panel and make sure the test ground isnt hooked into the test plug. Otherwise yeah flashing all the time while running is a misfire.
