Re: horn
Originally Posted by msg115031
my cruise control does not work. so from what i read the clocksping is bad right.
Maybe, you need to locate the black/green stripe wire going into the plug for the clock spring at the steering column. This is the horn button wire. If you ground this wire and the horn sounds, then the clock spring is the trouble. If it doesn't sound its not.
One Arm Bloke.
Tell it like it is!
