Re: horn
Originally Posted by msg115031
air bag light has been on since i have owned the car (6 yrs) i don't remember if my cruise works or not. What is a clock spring?
A clock spring or is a special rotary electrical connector which allows a vehicle's steering wheel to turn while still making an electrical connection between the steering wheel airbag and the vehicle's horn and other electrical devices, such as cruise control. The clock spring is located between the steering wheel and the steering column.
It's called that because it simply looks like a clock spring that winds and unwinds. This is how a positive electrical connection is made to the airbag and still be able to turn the wheel back and forth.
The horn and cruise control circuits on the steering wheel run through this clock spring. Check to see if the horn and cruise are working. If not, you probably need to replace the clock spring.
OK, my horn does not work. I have checked the fuse and the horn itself and changed the horn relay and still no horn. Can anyone help.
Based on the above information, it seems that the clockspring has been bad for many years. How long has the horn not been working?
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
