Re: New brakes and rotor rubbing HOTT
Originally Posted by Crazy_pilot
Did the caliper slides move freely? Particularly the lower one? It should slide in and out easily. If it's stuck it will jam the pads against the rotor.
+1 Buy a new caliper if you care about your car. Probably can be fixed but you would be better off getting a new or remanufactured caliper. edit: Get a pair, do both fronts.
