Originally Posted by cdigerlando
Have you thought about installing an STI water pump and modifying it to work in our engine? The impeller is different than the SVX impeller. Another option would be to shave the impeller so that it would create as much suction head.
The STi impeller may be designed to operate better at high rpms. It seems like ours will just not work at these higher rpms.
I've considered using the STi pump in the SVX, but until now could not see a reason why.
The sti impeller is the same. The WRX has the stamped steel impeller. I put pictures in post #1106
![Smilie](images/smilies/smile.gif)
The WRX/Sti pump casting is ~8-10mm short and won't work on the Eg33 as It will not line up properly with the EG timing components.
