Re: Oh No, What Did I Do?
I would also assume it is the IAC that is causing this problem.
My mechanic told me long ago, that this specific unit should not be cleaned.. ever. Once you try to clean it, its 'internals' just get messed up and it will never function properly.
You used the carb cleaner which does a job even better than thinner with metal surfaces. I second YT's opinion in this..
