Re: STI Cam pulley's
Originally Posted by TomsSVX
Danny, our scissor gears cannot be tampered with or adjusted... They are held onto the cam with a snap ring and a spring washer... If you widened the dowel slot or used a smaller dowel, it would only leave slop. VVT is not going to happen with this engine unless you switch to totally different pulleys all around and work in some actuated pulleys.
Tom I thought they were held to the cams by the spring and washer but they are locked with a pin. So I thought filling and readjusting the pin will do the trick.
