Sowise, reread his post, He did not say that he got a code #14 but that he was told fuse # 14 was bad.
The 16 flashes of the power light on start up means that there is a transmission code. You will need to check the code (process isn't brain science) and report back with your findings.
Here is a link with the PDF on how to check both current codes as well as stored codes. I would suggest you check both.
