Re: Wire issue under the drivers seat.
Ok same issue, new problem.
My '96 P/Windows P/Dr seat, sunroof all quit at once. The combo of post searching, and looking at the wiring diagram in the PDF manual, led me under the drivers seat.
While under there I found the following:
#1, The relay is functioning, and getting 12V to pull in the coil.
#2, the circuit breaker is good. (reads 0 ohms)
#3, there is no voltage on the yellow wire from the 30A SBF under the hood, SBF is good. There is voltage at the fusebox.
#4 the SRS/meter fuse in the interior panel is good.
I was able to tap voltage from the coil side of the relay to run my windows, but I'm at a loss as to why there is no voltage to the load side of the relay. I'd much rather use the heavier guage wire for these high load accessories. Also, there is little to no corrosion on any of the terminals inder my seat. Subaru must have learned a trick or two, as all of my terminals are full of white dilectric grease.
Any clues to be offered would be GREATLY apprecieated.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:
'96 SVX LSi #767 Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car.
