Originally Posted by 92 SVX
no 96-97 here but I believe the getting around emissions is if you have a obd2 car, your legacy, and you run a obd1 ecu, the obd2 scanners will obviously not work. If you are able to put a obd2 ecu into your car with this engine swap you will be able to access the obd2 thus it will pass emissions.
I think the main difference will be a 3rd O2 sensor, behind the main cat. Your legacy should have the cat there so you will just need to splice wiring, after you find the pin locations.
Really that is great to know. This way incase I decide to sell (much further down the road) I will have a swap that will pass emissions. Good info and I am going to have to find a diagram for the 96-97 ecu and pin out the wiring for the 3rd sensor.
