Re: STeeL's built motor/turbo build
Originally Posted by TomsSVX
It does... most people wouldn't know where to start with tuning in general though so as a precaution I have recomended they get it tuned by a professional... I don't lock my maps, so they could use the map I give them as a starting point
ok, I guess the lack of tuning skill does make sense for the SVX community. Great that you don't lock your maps. Do you have the MegaSquirt adapted to the SVX and have a set of base maps for it?
Mychailo
Visit my locker
