Re: STi brakes, the brute force way!
Just a minor update... if anyone was planning on building an adapter based on the posted plans... hold off a bit. I'm pretty sure the current position of the ball-joint will result in way too much negative camber due to a difference in length of the strut mounting arms on the two knuckles.
The good news is that it appears that the ball-joint taper is a standard 2in/ft taper (or 9.56 degrees) and I can get a reamer tool for it... they're just around $100 ... but that's still cheaper than an hour of labor at the machine shop and then I'll be able to make several adapters if I end up with an issue (like too much negative camber as described above).
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
