Re: Noise Under Load and Vibration From Engine
Called the Flywheel company and they said the flywheel is zero balanced and therefore does not have any marks on it. You can put the pressure plate in any position and it should be fine.
On another note I was looking through flywheel diagrams and noticed the small plate that is put on with an AT flyweel does not go on with a MT flywheel. I had put that on with mine. Could this cause an imbalance?
94 Laguna Blue LSI 126k (stock)
92 Silver LSL 106K (highly modified)
