Re: new coilover opportunity (March, 2010)
Originally Posted by JACOBBOCAJ
I am definitly interested in these. $1900 bucks is only a little more than the gc/koni setup would cost. Do we need to give money up front or when they are done? And if one of these breaks would they be willing to make replacements?
I'm sure that money will be required up front. The coilovers are fully rebuildable. The majority of the extra expense in creating a new coilover is in the upfront design work. After that, machining parts is pretty much just a matter of inputing the cutting program into the CNC. They back their products fully, and as long as they are in business, replacement parts will be available.
Mychailo
Visit my locker
