Originally Posted by Traitor_Moron
Thanks for the advice... havent checked the wiring yet but my front strut mounts are dead and I got a puddle of hydraulic fluid in my lap when I removed the hardtop so im sure the hydraulic rams need to be replaced
Jeremy-
The fluid is most likely coming from the latches above the windshield. It is very common that they leak.
For all the information you could ever want about the soft top system, see here:
http://www.benzworld.org/forums/r129...ml#post2262978
The soft top on mine doesn't work at all, for the record. I've only put it up manually once to see how it looked. Otherwise, i use the hard top, or it sits in my garage with no top at all.
Mike
