Re: Reading ELEVEN sign-up list
01. svxcess
02. Wikedjuggalo
03. Green1995SVX (maybe)
04. SVXyGirl
05. Mike621 +1
06. MAXSVX (maybe)
07. LetItSnow +1
08. 1986nate + 3
09. shelfy
10. baddogi
11. Subeman90 + Denise
12. ensteele
13. Hocrest
14. Subbyru89
15. Tim
16. Paladinwkh
17. Budfreak + Mrs. Budfreak
18. Wannarace928
19. Larry III & The Beautiful Naviguesser
20. Jnthn_Sctt
21. processengr
22. redlightningsvx
23. Sean486
24. cozykat + Ranatsu
25. svxfiles (if I'm not dead.)
26. Green_Eyed_Lady
27. jodo_baggins + 1 (Reading noob)
28. Ron M. + squeeze o' the day, Cheryl
29. Fancycargal
30. My92SVX
31. radarwhiz
32. rvnmaniac and Mrs. rvnmaniac
33.Joel
34. Shotgunslade
