Re: SVX Engine cooling "Again & Again"
Originally Posted by Dessertrunner
Here is the unit used to pressurize the radiator when I did the test. It is a radiator pressure tester and have the added advantage that it can let me try higher pressures then the engine normally operates at.
Tony
Tony,
After reviewing your posts covering the testing you are now using as evidence, I can find no evidence that you used such a device or an any way applied significant pressure.
Trevor, New Zealand.
