Originally Posted by Dessertrunner
Trevor what purpose does an over pressure acheive. You keep saying it needs it but don't have one single reason to justify it. With out justisfication it is "Blue Sky" stuff.
Tony
Tony,
I have not suggested "an over pressure" test. I have stated that pressure should be present close to that which is normal.
No test can be valid or even worthwhile, unless the what is being tested is closely, if not exactly, simulated. Your set up does not provide conditions even close to reality.
You argue against what is fact. Blue skys are the stuff of fiction.
