Originally Posted by SomethingElse
got to work..opened it up..sure enough...the spring was slightly deformed causing it to only make contact in one small area...after years of being abused in one spot it began to develope craters
Its just a plain relay the same one used for the band-aid fix 12v 20/30 amps
the #s read 0332204150
the location,
Attachment 12853
Attachment 12854
Adding my two cents. Better pic of location to post in parts location section of How-To.
You will note that it is a long mounting bolt (14mm head) that DOES NOT need to be completely screwed out. The mounting bracket on the relay is slotted and will slip out when the bolt is loosened. IF the part you buy has a mounting hole, simply clip the ends as in pic StarterRelay4.
Bosch part# 0332204150
Autozone part# 19861
Carquest part# RY115
And I fully agree--WHY do the bandaid fix instead of the REAL fix???? Uses the same part.
Lee
