problem with constant heat supply
Now that the really cold has hit the northeast, my heat is erratic. When I'm driving the heat seems to respond to the temperature setting. But when I stop for a light or any other reason, the heat stops and the air blowing thru the system is cold. When I start to move again, the heat returns while the car is moving. I tried to clean the temp sensor on the dash but that had no effect. Any suggestions?
