Re: Wheels that fit the SVX
Mazda and maybe toyota 5-bolt wheels might, as well.
Any FWD car, foreign or domestic, with a standard 5x114.3mm (same as 5x4.5 inch) bolt pattern, more than ~40mm positive offset, the higher the better (stock is 55mm offset, on 7.5 inches of wheel width. offset is likely stamped on the wheel somewhere... I think with a jj prefix), and at least 57.1mm center bore hole should technically work.
As long as it takes standard conical-seat lugs, any standard (not too wide) 12x1.25 thread pitch, cone seat lug nut should be good to bolt them to your car. the stock SVX lug nuts probably won't work, unless the lug seats are the same as the SVX OE wheels... (sleeve and washer style seats, not conical.)
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
