Re: SVX Engine cooling "Again & Again"
Originally Posted by TomsSVX
Because if I pump it directly into the block, it will not make much of a difference because that is where the coolant is being sent in the first place. Sending it to the head allows coolant that has been cooled by the rad to be sent into the hot stream to help it be more efficient in its job of thermal absorbtion before it hits the hot spot.
Like I said though, I doubt it will this considering how small the X-over manifold really is inside. I truly believe it is simply too small to move enough water to be efficient for the LH side of the motor
Hope this X-over method works as you expect Tom, but just in case it doesn't... will it make sense to tap the left block (not head), connect it to an electric pump which works automatically at a certain temperature then to a small outside rad (bike rad?) then again to the right block?
This way you will be transferring the boiling water to the rad for cooling then inject it again to the right side.. am I making sense?
