Originally Posted by oab_au
Yes but, I am using the same TCU, just the EPROM has been changed, same electronics.
Harvey,
Is Phil to accept, that your rather confusing post states ----
After installing in my SVX, an EPROM supplied by Phil, I Harvey, found it necessary to change the C solenoid from a N/O to a N/C , otherwise my car would not operate correctly ?
P.S. Are you stating that you now have the fuse switch, permanently installed ?
