Re: Clutch/Flywheel combo
A good flywheel/clutch setup that I have heard of... as I have been looking around for my Legacy GT...
ACT aftermarket clutch disc and pressure plate for 2006-current WRX 5MT.
2006-current Subaru WRX 2.5T flywheel and bolts (stronger, less likely to ream out than 2005-2009 Legacy bolts)
new throw-out bearing, engagement fork, and other misc bits for assembly. (compatible shift fork with whichever clutch slave cylinder you have, push or pull type.)
I've also thought about a stainless braided hydraulic line for the clutch master to slave cylinder, for better feedback, and less hose-flex.
ACT has a streetlite flywheel for that application that is lighter than OE, but if you wanted a more normal-mass flywheel for the EG33, the WRX OE flywheel is probably closer to that.
But I don't have first hand experience. That will probably be the setup I convert my 2005 Legacy to, and get rid of the stock Sachs crap, and the OE dual-mass flywheel that the Legacy came with.
I am not sure what 5MT converted SVXs are running, but am interested to see what gets posted here by folks who do know...
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
