Re: should I "seafoam" my SVX (last resort) VID. inside.
Hi,
not sure if I fully understand your problem. However, if you have a "knocking noise" (from the valves) when you fire up your engine, this might be normal. This engine has a self-adjusting valve clearance system, that is opperated by oil pressure. If your oil level is low, this does not work properly. Check your owner manual for more information.
Cheers,
Brit-tic
