Re: Individual Throttle Bodies.
Originally Posted by Dessertrunner
Okay spoke to the guys that make the throttle bodies and they can build a unit like I first looked at that has 3 bodies on it. They are 20mm thick so I am going to try to sandwich them between the intake manifold and injector manifold. Then remove the existing throttle. My guess is that the existing manifold will give enough flow to satisify the need for air.
Tony
What is that going to achieve? You will increase length the inlet tract, to lower the rpm that it will resonate at, and there will be no vacuum for the Fuel reg, brakes, purge, etc. How is it going to do the Idle control? Not .to mention the complication of setting all the throttle butterflys to work together.
One Arm Bloke.
Tell it like it is!
