Originally Posted by legacyau
I know mine was a plug and play they didnt change any wiring they just plugged in the harness's and the speedo still worked ![Smilie](images/smilies/smile.gif) i do have a duty solenoid issue(disconnected/manual switch) because the front sensor isnt hooked up
cam
That's nice to know cam. It means the speedo can read the road speed from the rear sensor as a backup.
If yours has no connection for the front speed sensor [SS2] then the TCU would have no way of comparing front vs rear axle speeds so as to re-apportion traction.
Did you ever think of wiring in a Japanese TCU in place of the original OZ one you have? That might cure the problem.
Black Betty [Bam a Lam!] '93 UK spec, still languishing
Betty
Jersey Girl Silver '92 UK [Channel Isles] 40K
Jersey Girl @ Mersea
Candy Purple Honda Blackbird
Plum Dangerous
White X2 RVR Mitsubishi 1800GDI.
Vantastic
