Thanks Keith! Well i put the battery in, the codes had cleared on their own while the battery was in here, still wont start. The starter seems like it is laboring to start the car, so I have determined that a pulley may have frozen somewhere along the timing belt. I hope its not my new waterpump!! The back of the belt appears to have some light friction marks, and the wierd thing is that when the waterpump seized before... the car would still start up, but just make screeching noises and smoke from the timing belt....
So perhaps one of the smooth idlers can cause more drag when it seizes...or one of the gear idlers?? The timing belt is turning I have verified that, and I noticed gasoline dripping from the exhaust pipe under the car... meaning its getting fuel injected into the cylinders. Im stumped, I just hope to not have to yank apart the timing stuff again since im all the way out here and dont have a garage or all my tools
The repeated cranking of the engine did not throw any codes so far.
Once again the car just stalled initially going around a left turn, and in the morning when I first try cranking, it starts for a half second roughly then dies... and wont turn over at all until the next day. Any more ideas would be greatly appreciated!!
New?? Find the downloadable SVX Online Service Manual
Here
RECOMMENDED READING for newer SVX owners
Here some cool info if not fully accurate.
