Re: HELP! 430 miles from home...
Well I put the new sensor in... the old one was corroded and fell apart on removal .... the battery was low, and for some reason the codes wouldnt clear using the two jumpers method. I tried starting it with the low battery and the present codes..... wouldnt start. Could this be because I have to reset the computer?? I hope so!! Im charging the battery right now so hopefully ill be able to report back soon with good news. No dcb it just died and wouldnt start again even with the pedal pressed.... im praying this is the problem.
