Originally Posted by svxistentialist
If I want to change the final drive in my VTD, I am presuming I have to fit a rear 4.444 diff say. To match this in the front I'm presuming I will have to change one of the pinions in the front diff to give the same 4.444 output ratio, so that the front and back axles are matched.
Yes.
Assuming I am correct so far, and knowing the front and rear sensors are both inside the gearbox, then I would deduce that both sensors are "seeing" equivalent revolutions, and therefore would send matched speed signals to the TCU.
Yes. On a Euro/Aussie VTD box with both sensors internal.
However I would expect the clock to be reading fast by a big percentage in this case. To make the clock [speedo] read correctly I imagine it would be necessary to give the TCU a new constant for multiplying out the speed.
Probably. My description above relates to sensor 1 on a USDM ACT4 box. But you are asking about sensor 2 on a UK VTD box. I will investigate how it works and get back to you.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
