two batteries connected in series makes 24 volts for the circuit you want the 15v on and you can still wire everything else connected to just the 1 battery for 12v. Two batteries will last better for your test anyway.
Originally Posted by TomsSVX
True, but it won't help me get over the 13.2v it is usually running at. A simple solution would be to use a 15v DC power adapter with a pot and a voltmeter... I am still waiting for my Delphi pins to show up. Once I have those I will be building a unit to do so.. I will also be wiring the harness for the TCU as well... But I am still waiting for 100 pins to show up at my door.
