Ok, So I finally remove the axles.... it was sooo easy
but There's sooo much stuff to remove under the car in order to lower the gearbox. Even the exhaust pipes with the pre cats had to go... so I guess that's a good excuse for a straight pipe upgrade and high flow cat replacement.
Is there something I should know before pulling the tranny of the engine?? Like some spring is going to jump suddenly or some additional tip that might save me hours of frustration later??? Do somebody has a 6 speed MT just lying in the floor that I could use???
Also, I'm going to buy a Fidanza aluminum flywheel for an Impreza 2.5RS it should work right??? I'm taking baby steps on this since I dont want to take off the gearbox in a couple months.
Thanks guys
