Re: The people have spoken!
Please compare Obama's acceptance speech with Bush's. Obama went out of his way to reach out to those who didn't vote for him and to stress that we all have to work together to address our very serious problems. Bush said that the election had given him "Political Capital" and he was going to spend it as he saw fit, which was a polite way of saying "f*ck you" to the people who voted against him.
I will also say the McCain's concession speech was very gracious.
It is really nice for a change to listen to a president-elect who has a brain and can articulate what is in it.
