Re: to drain the oil out of the rear-end...
I've never had one of the bolts mounting the rear diff break off, if your sockets are not that good they might round off... Sometimes the stud in the rear diff cover will back out of the cover instead of the nut losening, but its not a concern, you just have a bolt then.
its fairly simple just time consuming as getting access to lower the driveshaft out of the way requires dropping the exhaust pipe according to the FSM.
