Originally Posted by dromano
Thanks Tom,
Will do, leaks? I don't want no f*ing leaks, I'll follow the advice of the gurus and
follow the manual instructions. I'll probably do more than the manual instructions
Pick up some Perma-tex ultra-black and use it to form a thing bead around the mating surface of the oil pump. Make sure you make a bead around the o-ring but not enough to allow it to push into the 0-ring grove. Also, coat the threads on the three oil pump bolts on the right side (passenger side) of the engine. I will try and scan the page out of the manual for you when i get to the shop next.
