Re: S.O.S. 92 svx, code 13, replaced all sensors$$$, still code 13?
ok, it was the timing belt, here is what i have learned: if you get a code 13 and its not a sensor, remove the timingbelt cover near the battery and check its tension.
I was only the two top nuts that i had to remove to check.
i had it towed to my drive and now im going to start removing everything between the front bumper and timing belt.
I ordered a new timingbelt from napa, its total was surprisingly under a hundred $.
when i remove the old belt i am going to check for play in the gears.
will post what else i find if anything, thats including problems i run into and what i should have done to prevent it.
92 SVX-LS, BLACK, 189k Fiona
