Originally Posted by Nomake Wan
Yes, both fans are running full-blast.
So lemme get this straight. Run the car for 50 or so miles. Stop. Remove the cap (which it says not to do). Dodge coolant. Refill so the coolant level is at the neck. Rev the motor.
If revving the motor shoots coolant out the neck, it's a head gasket?
Really?
After the pressure of the cooling system is released there should be no more gushing of coolant. If a head gasket is blown and letting combustion gas into the coolant then you will get a fountain effect. The fountain may not be there at idle (prob will be though from the # of cars I have seen), but rev'n it will make it known.
But...
Sounds to me like the water pump impeller is gone. I don't work on cars anymore, so it's just a thought.
blk 92' LSL w/ average mods
