Originally Posted by svxsubaru1
Thanks for the quick responses. . Iam going to go sown and pick a 95 5spd drive shaft after work. So i don't necessarily need to shorten it, but if i dont i need to trim the cup on the trannie end of it? But if i do shorten it which end do i shorten, the shaft in front of the carrier bearing or the shaft behind the carrier bearing? Thanks again
If you shorten it, it needs to be between the transmission and the center bearing as that is where all the length differences are
