Originally Posted by Davestone
The leak seems to be coming from a hose on the left side of the pump. I didn't look too long, but how hard is it to replace that hose? Is there a write up or is it straight forward.. Sorry I'm still learning about engine stuff so be as simple as possible please
it would be fastened on with a hose clamp and you can easily just look at it and see where the other end goes
Should be pretty easy to look and see where the fluid is coming from.
was it leaking before you replaced the "O" ring?
Keith
