Don't be fooled, the guy in the diagram may be smiling while doing it, but i doubt you will be. This is significantly easier on a lift, doing it on jack stands would be a huge pain.
So there's a burst in the hard line between the tank and the front? Can you relieve the pressure on it, find the hole and repair the hole? If so, that sounds significantly easier.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
