Originally Posted by svxistentialist
It is age related.
The solder joints get loose due to the extremes of temperature cycling under the hood over time.
You question is good though. This is something that, at the price, I would immediately consider doing if I got those cutting out erratically symptoms. What would you have to lose?
EDIT: But no, I would not consider touching it as a maintenance procedure, unless I got the symptoms. Leave well enough alone, don't cross bridges yadda yadda
and on the can, it says the MAF should be sprayed each time the air filter is changed. Of course, they sell the stuff and want it used! I probably will play their game and do that.
The soldering thing is a different ball game but With my
doner MAF still working, because it is an extra one, I will probably go into it and re-solder it to get a leg up on a possible problem.
But that is just me.
Keith
