I get the density part on the engine side of the SC but I still have trouble saying the revs on the SC can be nearly the same ans you will get different power. Pressure is effected by final air temp. The intercooled engine will require the SC to pump more air to get the same psi as the uncooled. In simple terms if the air heats up as it is pumped through the SC then it will require SC to pump less to get the to the 9 psi.
Maybe I will have to think it through more I just can't get the part of the SC revs being simlar in both of your sheets.
Do you understand this part in the Autospeed calc
Theoretical outlet temp = 293 x (2.1)0.286
= 293 x 1.236
what maths is being done between the (2.1) & 0.286 to get 1.236 as I get 1.2306. Is it ment to be to the power of.
Tony
