Tonight I swapped around injectors 1,3 and 5 (1w/3, and 1w/5).
W/ the 2 blue wires plugged in I started the car for 30 sec to clear the code. Next I removed the wires and restarted and ran it for a minute to get the CEL to reappear. I checked and still got a code 14.
Just in case I didn't clear the code properly I have disconnected the battery to drain the memory. the air is clearing for now, but I will recheck for codes later tonight.
I also checked injector signal on 1 and 3 and they both looked the same, so I am opening the best bottle of beer ever: a Samuel Adams Double Bock!
I am starting to think I know why the car is flooded w/ gas and will post what I think after I try to correct it. I am embarrassed to say what I may have done wrong.
As LAN brought up, I have used liberal amounts of vaseline on all the o-rings. He made a good point that a torn inner oring will flood the motor w/ gas while a torn outer oring will flood the engine bay with gas.
p.s. My stock injectors have ohm readings from 11.5 to 12.1 which is within spec., and same as the replacements.
blk 92' LSL w/ average mods
