Race car weighs 1100 lbs. with fluids. Trailer (already specced out) weighs 950 lbs. H6 Outback is rated for 3000 lbs towing. Figure I can throw on a spare set of wheels and some tools and still be under 2400 lbs. Am looking for a tranny cooler.
