If you take an impreza/wrx/ STi seat you will need to bend the tabs on the front mounting tabs down. Then cut the rear feet off completely. This has a dual purpose of getting the seat down to the height of the stock seat. You will then need to get a piece of steel from home depot and weld a tab onto each rail in the rear. This tab is flat and simply extends out past the seat rail by about 2.5 inches (I think). Now simply drill a hole in the steel where the floor mounting points are and you are done. The seat now attach to the floor at 4 points whereas before they had three on the floor and one bolted to the center hump.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
